Two hours?! How? I've had mine in and out half a dozen times and no way could I do it in two hours :blush:
It aint really a proper/improper way, probably a bad choice of word. Some people can take the harmonic balancer off without taking the radiator out. I use a puller so I have to take the radiator out which obviously adds some more time putting it in and out and bleeding it.
Edited by PM-R33
https://www.sau.com.au/forums/topic/333696-tomei-poncams/#findComment-5413495
oh right.
ive done quite a lot of cam installs... i do it without taking the balancer off. it involves pulling the gears off the cams and putting them back on the same way. quite difficult and i dont recommend it for someone who hasnt done it as there is potential to get it wrong.
it does however save me an hour of stuffing around.
so worst case.. 3 hours to do it with balancer off.. still shouldnt be any more then 300 @100 an hour
https://www.sau.com.au/forums/topic/333696-tomei-poncams/#findComment-5413516
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
