hey guys and gals
i am changing over all my studs and replacing the ex manifold gaskets on my rb20.
first thing i am wondering the gasket kit that i got its got both the whole 6 all the together gasket one and also the 6 individal gaskets, which one is better to use???
i am replacing all the studs also since i already had a few broken ones so might as well replace them all. is there anything else i could be doing when fitting up the new ones?
well since i had a few broken studs i am missing a few nuts and washers can i just go to my local hardware store and get like stainless steel nuts and washers??
last thing. the tensions, when i was taking all the turbo, dump, ex manifold i did spray wd40 on all the nuts before taking them off and all, just when i went to take them off there wasnt much effort in taking them off at all, like i didnt have to even crack loose a nut, it was just a lil too easy, soooooo how tight do i really have to do themm upp
thanks
https://www.sau.com.au/forums/topic/333792-gasket-studs-nuts-and-washers/
dont use a rattle gun, most of that stuff doesnt need to be as tight as you'd think. just nip it up fairly tight with a normal sized ratchet.
nissan want too much for exhaust manifold nuts so i got some from a fixings shop in wangara, cost about $5 for a full set. just take a stud in and get some high tensile nuts in the right thread
little off topic but if you have a spare exhaust manifold gasket i'll buy it off you
Rattle gun won't fit down there easy...infact depending on the manifold, sometimes even a ratchet isnt the go. Need to use uni joint, or a spanner.
As for studs and gaskets. Use Nissan items, they're more expensive, but they're of alot better quality than the other shit.
obviously dont use a rattle gun need ring/open ended spanners 14-15mm depending what nuts you use and socket set with either 14mm or 15mm sockets
i do mine pretty tightish obviously the areas that you cant get a socket to just tight it up as much as you can with the spanner as your restricted for torque and personel preferance i use loctite
can get high tensile nuts from bunnings or just go auto one
yeah nice one there andrew haha. i dont need to know sizes here i have already taken everything off. so do them up pretty tight, guess i would also need to get washers tooo with the high tensile nuts???
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
