Hey everyone,it's time to let go of my pride and joy. The reason I'm selling is that I just dot have enough time for it anymore and need spending money for overseas trip next year . This would be one of the cleanest 1994 r33 out in Sydney.
I have owned the car for 4 years and I'm the 2nd owner since it was personally imported into Australia. The first 2 years it's been in storage in my garage which was started once a week and taken for a drive around the block to keep all the running gear in working order.
The car was also Resprayed 4 Christmas ago ( Ford perlecent blueprint blue) and still is in pristine condition. It has an original r33 gtr front end, everything was done properly for the conversion from gtr bonnet hinges to the gtr bonnet latch, front reo and headlight spacers, this cost well over 4 grand for the conversion. It's a one of a kind gts. As for interier wise its in very good condition, all the trims and dash are straight and always conditioned. There is a cigi burn on the roof and one on the back seat from the last owner as I'm a non smoker and the drivers seat moves a bit but is still in very good condition for a 16-17 year old car
The car has never been in a accident and is clear on revs. There's around 3-4 unnoticeable small dents around the car but can easily be fixed. No rust spots at all as it's common for older skylines.
The r33 has always been serviced every 5-7 thou k's and gearbox and diff at 20thou k's by yafuz @ unigroup engineering a very trusted workshop, and no expense has been spared. Average round 400-450 km out of a tank which is very good for the power it makes. Always premium fuel used (shell v-power). Has a nice cat back exhaust system that's not loud at all just a nice rb growl.
Plenty of money spent on this car to get it how it is today, save time and money and buy a soft/mild tuned economic and reliable car. Also has top of the range mongoose m80s alarm.
That's about it, posibly one of the cleanest r33s on the road and needs a new owner to get some use out of it show it off.
Engine:
130xxxkms
Apexi PFC ($1200) tuned by yafuz @ unigroup make a safe 191.3 rwkws (tune cost 700)
Apexi boost controller ($430) max set to 12 psi ( always driven on low boost 7psi)
Hybrid front mount intercooler with saber fittings and clamps
Apexi intake filter
Highflow cat/back exhaust turbo world muffler
Greddy type s plumbed bov
Can supply most stock parts including ecu
Suspension/brakes/body
pedders shocks and lowerd springs ( front right knocks a little bit , can hear it sometimes when I reverse out of my driveway won't hear it anyothet time was going to replace with coilovers any way)
Front strut bar
New front brake pads
Resprayed 4years ago blueprint blue ($6.5k job) looks stunning after everywash
Front half gtr conversion ($5000)
Series 2 spolier
Explosive sideskirts bought from team jet speed
Will come with a trial rear bar unpainted bought recently ($240)
Price: $15,000 neg with 1 year rego
Contact: tilla 0402362885
Not interested in any trades atm
And needs to sell by the end of year so plenty of time.
please no time wasters as I'll can spot you out a mile away :(
Please don't comment unless interested cheers
Pm me for more pictures
Forgot to mention it has:
excedy twin plate clutch hard to get use to but very nice bitey clutch worth ( $2300)
5% tints all round with life time warranty
Mint original gtr rims with 70% tred
Hks turbo timer
Front foot well leds
Cyber stork white gauge dials
Greddy boost pillar with apexi el boost gauge
And havnt got a head unit for it as the other one stuffed up but has clairon 6 inch splits at the front and rca cables ready for amp and sub
And that's bout everything
Cheers
  • 3 weeks later...
  • 2 months later...
$13,500 rego till mid next year
new excedy clutch
machined flywheel
machined all rotors
new front rear pads
just spent another 1500 on it!!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
