Model: GXE Nissan Skyline
Year: 1989
Kilometers:Unknown
Transmission type: low kilometer 5 speed Rb20 box
Engine: Silver-top Rb20 Turbo
Colour: White
Modifications:
-silvertop rb20det conversion
-brand new Xtreme heavy duty clutch
-machined fly wheel
-3 inch cat back exhaust
-vg 30 turbo
-hybrid fmic
-GTR fuel pump
-thermo fan
-boost controller
-pod filter
-locked diff (mini spooled)
-rear slotted rotors
-monroe gt shocks
-lowered pedders springs
-front nolathene bushes
- 4 Ti rims with all 4 center caps
-new kenwood deck
-kenwood rear 6x9's
-kenwood front 6"
Roadworthy Certificate:No
Registered: Yes till 25th of august, I wont be renewing the rego untill the car sells as i have a company car which i drive.
Accident History: None
Asking:$42000ono
Contact Details: 0401261531, Nathan.
Other Comments:Firstly the car is NOT registered with the Rb20 now thats out of the way unfortunately its time for me to sell my Skyline i've had a lot of fun with it but i have just moved in to my first house and need the money for house stuff, As it states above its an Rb 20 turbo which has been dyno tuned by morpowa making 172.9rwkw @14 psi, the paint work could use some attention the roof and front quater could use a respray it hasnt bothered me enough to get it sprayed and there is a minor dent in the rear quater panel where a socket set hit it form in the boot, Overall the car looks good and is fun to drive. I've also put in a brand new century battery and new extra bright blue white headlights.
Any questions give me a call or just come have a look.
cheers, nathan
https://www.sau.com.au/forums/topic/334125-fs-89-s3-r31-rb20-turbo/
pretty cheap considering bro.
gl with the sale. well worth the coin
what? $42,000 for this is cheap? maybe its time you put the crack pipe down eh lol jokin jokin, i know he means 4,200 but that not cheap if you cost in engineering and regency you end up with the same price as a engineered and regency approved one without all the hassle.
HAHA if any one wants to pay $42,000 ill take it.. but i am only asking $4,200. thanks Sneaky its cheap cause i need money for my house and i have a company car now so also need the space. Mungy your right but compaired to other Rb20 31's for sale that are not enginnered it is cheap.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
