Hey
I just got a Power FC Pro in my R32 GTR, I was wondering what levels or knock are normal and what is bad.
Like whats the max level it can go to but still be ok??
I cant seem to find any info
Im running my power fc pro on bass map atm due to waiting for $$ for tune, so will my knock levels go down after tune??
If anyone can help me with this info
Thanks
M3M3NTO
https://www.sau.com.au/forums/topic/33417-knock-levelsreadings/
This is a general FYI that should be available in a search.
The FC has a synthetic knock sensor. It is only a guide and really only as accurate as the sensors themselves.
A good reason is around 10-15 or less on load, a hot engine, all boost levels.
Older engines do anywhere from 30-40-50.
Make it what you will of motors in the 60/70+ range.
Again FYI.
My motor did a 7-8-9 before it blew.
It still does a 7-8-9 after the rebuild.
ie. I phuqqed a completely good motor but I still have a completely good motor after the new pistons etc.
T.
Your Knock levels will go down after a tune. If your car is knocking under load it could be leaning of a little. Your tuner will add some fuel at that point in the map, you can use the map tracer function your self to find exactly where in the map your car is knocking. The tuner could also retard the timing a little to reduce the knock.
Like TonyGTST said: Your knock sensor on the pfc is only really usfull when the car is idling, its main function is only to tell you if something is really wrong when first installing the pfc.
ps, when driving if you see the engine warning light come on back off staight away or you risk a blow out....
hope that helps.
We dont get Synergy in Canberra... it is Mobils high octane PULP, and its damn good (filled up my car in Sydney with it before heading back to Canberra). My car never knocks whilst driving above 3, its 99% of the time always on 1. Ive just had the engine rebuilt and its running pretty rich, which might have something to do with it.
i've hit 150 on my powerfc.
optimax is the worst fuel. ultimate is the best. i notice significant knock level differences when using the different fuels. synergy sits somewhere in between, probably closer to optimax.
i've never audibly heard it detonate.
Not this argument again. I would say that if you hit 150 knock on your PowerFC, it says more about your car than the fuel you used. I have never had a problem with Optimax. Although I only prefer it because the stations with it are more plentiful and I know where to find it cheapest. Only about 1 in 5 BP stations carry Ultimate in Sydney.
Once every BP starts carrying Ultimate I may change my preference but until then, or I strike a problem with Optimax, I will be happy pulling into any cheapass Shell I see and know that I can get 98RON fuel there.
In my area a few Mobils also carry cheap fuel until Wednesday or sometimes Thursday. If I'm out of fuel on one of those days and I see a cheap Mobil, I have no problems filling up with Synergy at 10cpl less than everyone else.
I use shell, and the max knock I got was 25 on standard boost and 63 at 1 bar, my power fc pro is untunned and running bass map till I get the $$ and some more mods
Im guessing once tuned my knock level will go down alot?
i have to admit that i cannot quantify what i claim with any hard evidence - it is purely observation and i say it with the utmost unbiased opinion.
i definately see no performance difference between the 3 fuels but i can firmly say that on higher loads when fueled with BP Ultimate my knock sensor reading will remain *relatively lower* compared to the other brands.
yes it's obvious the tune is poor towards the top end of the rev range, but my argument is the powerfc tune remains constant whilst my brand of fuel is changing (and i fill up each time with a full tank) and the trend is consistent.
yes the weather and time of day is definately a variable in this equation but my argument to that is i've had too many tanks of fuels in varying weather conditions to justify this reasoning.
id definately be interested in hearing what you have to say about the car over the fuel?
cheers,
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
