My R34 NA is starting to be a handfull i need some suggestions or solutions.
1) my Speedo lights are not working......so at night i cant see how fast im going, i have resulted to using a GPS to calculate my speed....., My freind was setting up my stereo do you think he could have cut or diplaced a wire related to the gauges ?, or if its a fuse possibly.
2) My tail lights are not working, my brake lights are.....I checked the fuse box and where tail lights is supposed to be its missing, i dont know why the hell its not there....or why the hell i didnt notice in the last two weeks i had this.....i dont drive that much at night.
Please help if you can. much appeciated.
https://www.sau.com.au/forums/topic/334555-need-help/
Try putting a fuse in there, it's will be the fuse blown or missing causing the problem. If you put a fuse in and it blows then you have a short somewhere.
Have you installed a new CD player recently? There is a wire behind the stereo, which is a earth with ignition off and a power with ignition on or vice versa and is easily mistaken for something it is not. So when this wire is used incorrectly in a cd player install, it blows the parking light fuse.
Have you checked fuses inside the car and under the hood? I know on 33's that particular fuse is in the boot, not inside the car.
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5421355
grab a multimeter and try a continuity test in figgerent parts of the circuit.
This will help diagnose where the problem is.
You may have to take the dash out.
It may be as simple as a blown gobe.
This is not a nice exercise.
Best of luck
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5422579
yes i did install a cd player, but i didnt drive the car at night untill a couple days later so i wasnt to sure if it was because we played with the wires, when i asked my mate who did all the installing he says it couldnt be. As for the fuses i have changed all of them under the hood after i did it, as for the fuses inside the car they all seem fine, which fuse would exactly be related to speedo lights, because in car lights fuse is working perfectly, so it might actually be a blown globe.....
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5422848
1. Firstly, unless your mate is a professional or knows what he's doing.. It's not always best to be cheap and let them have a go.. Can cost more in the end. However i'd check fuses first, then just pull the instrument cluster out and replace a bulb and check if it lights up.. then if that fails, i'd be checking your mates wiring to see if he's done something wrong..
2. Ummm... What is it your asking.. Just replace the fuse if it's missing.. Previous owner prob blew the fuse and took it out and not replaced it
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5422954
He has an r34 to and said his done it a couple of time on his, so i didnt really think to much of it. But i have replaced checked all the in car fuses today and they are all fine...., i guess its time to check the bulb out and im not looking foward to it.
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5424214
Why not.. They are easy to get to..
Drop your steering wheel down to it's lowest setting.. Unscrew the surround around your cluster.. Unscrew the cluster.. Pull out and disconnect plugs.. Pull out completely.. Check bulbs..
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5424497
Ok so i took the car to the car electrician and he bascially told me my Alternator is overchaging and around something like 15.5v, above the accepted standard, and he thinks thats what caused my bulbs to blow......, this really sux for a poor Uni student working once a week who wanted to buy pimped out rims and exhaust, he reckons 500 plus labour...... Im thinking i just Buy an original used and reconditioned alternator that these japanese distributing company is selling on ebay and get my family mechanic to give me a family discount lol.
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5428569
Problem solved, the lesson to be learnt is if your not a proffesional dont go installing a head unit, apparently its done a little wire frying in the Alternater and fuses and bulbs. All fixed now, but its set me back 350 but its all fixed now new wires, propely soldered Head unit, new bulb in tail light and speedo.
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5432846
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
