As title says....my 33 is at ESP currently for a bunch of upgrades, therefore when it's done I'll have some bits n pieces to clear off...
6 coilpacks to suit s1 R33 (5x red JJR coils, 1x standard) = $150
6 standard injectors to suit s1 R33 RB25 (370cc side feed) = $100
R33 s1 ECU (TBA) = $50
R33 s1 fuel pump (TBA) = $25 lol
3.5" front pipe, I *think* it was stainless (will measure to confirm diameter) = make an offer
The ECU and fuel pump are TBA, as I'm honestly not sure if they're standard parts. The fuel pump was said to be a "GTR" pump, and it's been mentioned the ECU might be a mines or something due to the decent power output the car has made without touching it.
All prices are ONO. If you don't think something is worth the price I've listed, say so. I have no idea lol. Just guessing from other FS threads etc.
All items are in good working condition to my knowledge. I am not replacing them due to defects. Having said that, I can't guarantee they won't f**k up, simply that they are working fine when last used about a week and a half ago.
Edited by Trozzle
https://www.sau.com.au/forums/topic/334946-fs-bits-and-pieces-off-s1-r33/
I will take coils and maybe dump.
I have a STOCK dump pipe (didn't list it) but the FRONT pipe is what I have for sale. By all means, if you want the stock dump too, it's all yours (for free rofl) but I dare say this isn't what you're after :)
If you want only the front pipe, chuck us an offer. I'm quite open as I don't really care for these parts lol.
Otherwise, coils will be all yours.
BUMP!
I should get the car (and the above parts for sale) back either today or tomorrow - so once I've got it back all these bits are up for grabs. PM me or call on 0431391359 if you want something, I'm fairly negotiable on these parts as they'll just sit in a box otherwise, but no massive lowball stuff ty :banana:
  • 4 weeks later...
FRONT PIPE NOW DEEMED USELESS AS IT'S A 2.5" FLANGE WELDED TO A 3" OR 3.5" PIPE. FAIL.
Everything else still available.
If you want to dump if ill take it off your hands, need some thin stainless so I can play with the welder.
Also, werent you selling a walbro pump? I left mine in the race car when I go rid of it.
Yeah, it also turned out my factory pump was just some walbro. Haven't looked at it, and it looks tiny tbh. Otherwise, I might be hanging onto the stainless pipe for now mate, as I'm sure you agree it's still very useful. If you actually want it to make yourself something, then by all means you're welcome to buy it as random stainless piping. Will be cheap of course.
  • 2 months later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
