mate your asking TOO MUCH, 3500 and a daily driver? your dreaming for the condition it is in
ill be surprised if you get more that 3500 for it straight up
im looking for an s13 but cmon thats a steep ask
ok dude fair call . :P
WHAT I SHOULD HAVE SAID WAS
$3500 and your daily shitter !!! :D
But getting $3500 for it ( as is ) i didnt think was stupid at all tho ,
if you can find me a 5spd sr20det blacktop with same or less mods with rego in better condition for cheaper than 5k ....
PLEASE SHOW ME WHERE?
As i must have missed them going through the (clean) STOCK , AUTO , ca18det and unregistered s13's on car sales that are being advertised for 3-6k ?? :)
mabey CAR SALES was my first stuff up???
so i had a look on NISSAN SILVIA.com , ok YES there are way better bargain's there compared to carsales.com which has just become the new trading post !!! ;):P
but NOTHING THIS CHEAP.
I mean seriously WTF ? I know the paint is rat shit ?
But i take your constructive criticism on board Dylan and ask you to PLEASE PM ME AN OFFER THAT YOU YOURSELF WOULD PAY FOR A S13 IN THIS CONDITION??
AND PLEASE , IF IAM SO DEAD WRONG WITH THIS PRICE PLEASE SHOW ME SOME OTHER s13's (like mine) that are cheaper than $4000??
if you can i will be sure to advertise this CAR FOR MUCH CHEAPER!!!!
but for now I AINT FOUND SHIT.......
  • 4 weeks later...
$3500 and your daily shitter !!! ;)
so i had a look on NISSAN SILVIA.com , ok YES there are way better bargain's there compared to carsales.com which has just become the new trading post !!! :/:P
lool think about it, 4k for your car then rust removal around sunroof or else no point respraying, repair the dent and the scrapes, full body respray, replace heavy duty clutch and then a new set of suspensions. The total all up would be more then a normal undamaged s13 sr20det. People know what they have to do if they decide to buy your car hence the trouble you have selling it and the low prices which are actually reasonable.
so i will put some good coilovers and spray it fix the clutch then what...
You'd probably still get on here and put your 2 cents in where its not needed .
f**k OFF UNLESS YOU ARE INTERESTED IN MAKING AN OFFER !!
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
