any suggestions?i tried to put on factory fan cover onto radiator and there's not enough clearance and the fan would rub against the cover.need to go for roadworthy this week need help thanks
do you need a fan cover around the fan?
ive never had one, had no issues with rwc
Have your trimmed it down?
If not, buy a radiator that fits?
You dont need 52mm for even a moderately modded car
i only have money for rego and rwc lol so i gotta make do with what i got lol.thanks for your input guys.you guys are real fast
ill go for rwc tomoro see if i have any issues hope not
i think you would have more issues if you cut your blades than having a fan cover on, you should be fine because the fan cover has nothing to do with handling on the road.
if you cut your finger off on the fan while working on the car its your fault and cant cause any hard to other drivers, unless of course you work on your car while driving on a free way, and your hand gets caught in the fan causing you to hit other cars.
thanks.ahhaha yeah i was worried that they wont pass it coz someone could cut their hand workin on my car.we'll see how it goes.thanks again for the quick replies
The fan will be practically useless without a shroud.
not true
are you suggesting a ceiling fan dosent suck hot air down when set to winter mode?
same situation, different location
Fan will be significantly less effective without a shroud, as air will take the easiest path, and that will be from its periphery rather than thru the radiator
OP - I slotted the top radiator mounts so that the rad is pulled as far away from the fan as possible, instead of flopping around. I then secured the shroud to the rad and it doesnt touch.
lol having this issue atm with a car I have here. We ended up getting it to fit but only without the shroud and then it ended up throwing the fan through the core. Yay fun times. It was a piece of shit X-cess brand, 52mm core. Certainly does not fit like they say it does
Why would the fan draw air through the radiator when it is much easier to suck the air from AROUND the radiator (the path of least resistance)?
There is a reason that you shroud fans, particularly when you want to draw air THROUGH a heat exchanger.
Anyone advocating NOT using a shroud, should share their crack with the rest of us.
Edited by bubba
There is a reason that you shroud fans, particular when you want to draw air THROUGH a heat exchanger.
Yeh the only reason we didn't use the shroud is because the blasted thing wouldn't fit with it on and the a/c is all removed. There aren't many options for the air to travel AROUND the radiator rather than through it. I know drift cars with the same radiator without cooling issues but it's a prick of a thing in a street car in stop start stuff
Wasn't having a dig at all and I'm not talking about it pulling air from the front of the car around the radiator but more that without a shroud it will just pull engine bay air from between the front of the fan and the radiator, and blow it out the back of the fan, as opposed to drawing air through the radiator.
On a track you have lots of airflow (less in a drift car because you're sideways but if you have nice big, properly designed air dams it will be fine), on the street, as you said in stop start stuff, it's going to be terrible and the temps will go through the roof!
IMO you're (and not meaning you Elite, more of a generic term :D) better off running the stock radiator with a shrouded fan than a bigger radiator with a non shrouded fan. Drifting or dragging with a big radiator and non shrouded fan will be ok as the water is just a giant heat sink, couple of laps or a run down the strip, then cooling off in the pits, no worries!
On a street car, as soon as that radiator gets heat soaked, the non shrouded fan is going to do 2/10's of fk all to cool things down, it will just move hot air about the engine bay.
If the engine fan won't fit, then get some thermos with a nice shroud.
Haha yeah np I didn't think you were anyway. I probably worded it wrong.
And yes, definitely +1 on pulling air from the engine bay. It's usually only a problem in traffic though as the air forced through the front of the car will outweigh the need for a fan anyway. Shroud is definitely better off in place rather than without though.
im not saying that its just as efficient, but the fan blades are designed to suck air from in front of the fan. if you hold a string to the side of the fan without a shroud, i bet the string wont get sucked into the side of the fan.
ive said it once, ill say it again, its less efficient, but not useless
imo
imo
The fan doesn't sit flush with the radiator..
not true
Fans dont actually suck hot air down... they draw it up to the ceiling, push it across the ceiling and back down the walls :down:
And its a completely different situation, as that fan isnt actually trying to draw air through anything. Its just moving it around.
I think its been proven more often than not that in Australian conditions, shrouds are a MUST for the clutch fan in traffic.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
