  • 6 months later...
Bump
dude pull out one of your bulbs and match it to a list of bulbs and see what it is. i think there are a few odd ones in r32
mine is a h3c i think there is a h1 but if you have the projector lenses then thata be a h4
https://www.sau.com.au/forums/topic/335611-hid-kit-for-r32/#findComment-5732247
