hey all im selling my brand new 35/40 selling due to the exhaust housing is too small.
bought for $500 so im asking the same, its never been used
FRONT COVER A/R IS: A/R .70
EXHAUST HOUSING SIZE: A/R .63
EXHAUST HOUSING FLAGE: T3 OPEN SCROLL
0423 888 507 (text only)
https://www.sau.com.au/forums/topic/335995-fs-gt3540/
If you end up buying a .82 exhaust housing let me know, im interested in down sizing my exhaust housing but dont want to get rid of the .82, might use it in the future after i do a rebuild.
And im in frankston as well.
https://www.sau.com.au/forums/topic/335995-fs-gt3540/#findComment-5438308
i wont be buying a bigger housing as i dont have enough money thats y i need to sell this so i can buy a new one with bigger housing or if someone has a housing they can swap
https://www.sau.com.au/forums/topic/335995-fs-gt3540/#findComment-5438393
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
