just consolidating all my stuff for sale into one page..
R33 turbo $60.00
only has the intake, exhaust and centre housing ie. no rotational assembly.
Suitable for highflows, exhaust housing is already high flowed by GCG recently, so you can get a discount of about $280 if you bring this back to GCG for high flow, since they only need to high flow the intake housing and put in new seals/ rotational assembly
Flywheel $50.00
came off R33 gts-t, just needs machining.
3 inch JJR bellmouth dump / front pipe $100
for R32 and R33 gtst
mild steel, good condition, bolts right up
R33 series 2 GTST rear seat $50
in good condition, pick up only
open to offers but please no low balling
Located in Chatswood area of Syd, I can post these except for the rear seat at buyer's expense
Edited by chiksluvit
and dump pipe price drop to $90!
come and take these away!
new price list:
R33 turbo $50.00
Flywheel $50.00
3 inch JJR bellmouth dump / front pipe $90
R33 series 2 GTST rear seat $40
would you know if the dump/front pipe goes below the rail or above it......i am after one that sits above the rail so it doesn't scrape.
being 3 inch some bottom section of the dump will definitely hang slightly lower than the rail, but i think this dump still has decent clearance since i never scraped it before even though the car was lowered a lot before when i bought it, it was low enough to dent a catback, but never did any damage to the dump
with this installed, if you bend down and have a look you can only see half of the pipe, while the other half will be covered by the rail
pm sent for dumpage
p.s. i read too quickly and i noticed it was mild steel so no need to answer that question lol
Edited by tomtom92
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
