Howdy all,
Has anyone else seen this issue?
It doesn't seem to matter if its hot or freezing the passenger side outside door handle when pulled open it sticks maybe 1 times out of 5 so you get in and the door wont close untill you get out and push the handle towards the car and it clicks back in.
Anyone seen this or has any idea on what i could do? I have a Nissan service tomorrow so i can ask them but thought i would quickly pose the question.
https://www.sau.com.au/forums/topic/336026-v35-sticky-door-handle/
So yep took the car in for its 30,000 service just for everyones information it cost 330 with fully synthetic oil.
The door handle i showed them the issue and they thought the bolt was loose but apparently when they took the trim off the mount for the handle was actually broken, and they had to take the windows and everything else included out to get to it. In the end they built a new bracket from scratch as they saw the price of the door handle and thought it easier and cheaper to make a bracket. So that just cost $100 more. And now the door works perfectly.
Now, THAT doesn't happen much any more these days. Good on those guys for being innovative and looking after you. They deserve a mention here - on the assumption you're happy otherwise with the services, that is. And they're Adelaide? Long way for me to drive for a service unfortunately... :ermm:
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
