I just got a pair of new number plates for my line. The plates are smaller.. according to VICROADS there are only two types of plates.. "big" and "small". They are both same in length but different in height. My plates are 37 cm.. but my line can only fit sumthing about ~32cm (in front). How do you guys fit the plates? Do you guys just bend them? If so, what or where do u go to get them bent without scratching it... or are there other alternative methods you guys reccommend? :)
https://www.sau.com.au/forums/topic/33629-number-plates-dont-fit/
thanks druzilla32, your advice worked.... even though i wasn't equiped with professional utilities.. i got the bend with a cloth, hammer and a pair of scissors hehe. (plz dun laugh :D)
I used the scissors to cut the top and bottom abit.. so it can bend easier, then i used a hammer to bend the sides, by laying it on a hard concrete corner and a cloth covering it so my plates don't get scratch. Now... it fits perfectly on my line.. and i'm very happy :)
and this thing is useful for all sorts of stuff.... and it is a
DREMEL!!!
Good for cutting grinding polishing etc etc
Although i didnt use it on mine (i kinda made them fit by bending, but the rear was tensed so when i tapped it with my foot one day *crump* big bend line.
I'll be getting myself a new set and dremeling down the edges to make em fit sometime soonish....
If anyone in the northern parts of syd wants me to do theirs let me know...
if yr in south syd, let me know anyway just give me a chance to find time to get down there.
I didn't want to cut my coloured plate..so I just bought some long threaded bolts and some washers to mount it in front of the bumpers. Have to tighten it occasionally but it's still intact, and no bending / cutting required.
I read in a previous post that BD4s sells a mounting kit for the Aussie plates?
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
