hey guys
im really lost for ideas atm I wanna make my engine look pretty as most of you guys would likes yours.
so if you have and tips and ideas and would be great if you could let me know.
im located in brisbane if there are any places here that dress up engines
thanks
https://www.sau.com.au/forums/topic/336443-rb25-engine/
If its a streeter I would avoid shinny stuff, Ive painted my cam covers-IC pipes-filter enclosure and catch can with a matte black VHT crinkle type finish paint, looks good and almost stockish, also gave my front mount a coat of flat black for the :P effect.
If you go all shinny its more likely that it could get defected, to the police shinny usually means modified which equals defect.
https://www.sau.com.au/forums/topic/336443-rb25-engine/#findComment-5442182
yeah very true man. yeah not gonna go the hole shinny way just want it to look nice and clean and what not maybe only paint the rocker cover a silver thats bout it i guess. where do you get that black matte finish paint from?
https://www.sau.com.au/forums/topic/336443-rb25-engine/#findComment-5442353
^^^ hahaha.. yes officer.. these do come standard with a highmount manifold..
+1, use as much black spray can as you want but it wont hide a highmount haha
also i wouldnt spray paint the fins of a intercooler if you want the stealth black should buy one that is ceramic coated as the paint restricts it from dissipating heat and holds it in.
https://www.sau.com.au/forums/topic/336443-rb25-engine/#findComment-5443407
My high mount has had the OK from the RTA inspection stations on 3 occasions and the whole car will be enginnered when the new motor goes in, only thing that needs changing is the catch can vent which vents to atmosphere, also if you ceramic coat the I/C it will trap the heat inside and not act as a heat soak, a light coat of paint to the outside is far superior as it will still let the heat excape from the I/C (heat sink), this is also why you paint a plenum and not use a ceramic coating.
You are allowed to do lots of mods to your car as long as you follow the details given by the RTA for modifications and if it outside of the guidelines all you need to do is build it properly so you can get it legaly enginnered.
https://www.sau.com.au/forums/topic/336443-rb25-engine/#findComment-5443544
its fine if u do a light coat
https://www.sau.com.au/forums/topic/336443-rb25-engine/#findComment-5443586
cheers boys for all the the tips the foward plenum idea looks good will have to go that way i think. Im obvisouly abit of a noob atm love cars but dont relly now shit lol but its all in the name of good fun.
https://www.sau.com.au/forums/topic/336443-rb25-engine/#findComment-5444442
i went with a foward facing plenum boys should be her tomorrow or wednesday! the reason why i got it so quick is that my fuel rail wouldnt fit with the standard inlet manifold.
do u have an aftermarket ecu???
https://www.sau.com.au/forums/topic/336443-rb25-engine/#findComment-5460384
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
