Hey guys, I'm just after some quick help or advice.
I'm currently building my second R33GTS-T but this time I'm going all out with everything on the car.
But to cut short I have a full veilside bodykit including wing (yes i know, but i like the out there shape)
Also have the "T Style" bonnet from www.carmate.com.au but with the middle cut out and 10mm clear perspex in it's place (still has all the same shape)
And to make things interesting I'm also hand crafting a wide bodykit for the car, nearly finished 1 side (front drivers fender, door and rear quater) looks something like the attached pic (fender, door and rear) but with the veilside kit. The R33 looks awesome and fat with a wide kit, I'm really loving it =)
Anyways I know stuff all about wheels =( all I know is i'm after something with a deep dish, preferably chrome (don't want black) and that the front fender is +1" and the rear is +2 on the original body.
I'm after some help or advice on what to get or where to look or rim sizes.
https://www.sau.com.au/forums/topic/336512-wide-r33-wheels/
youd need some serious offset to fill those guards properly. something like these
WEDS Kranze Cerberus II, 18x10-25 fronts, 18x11-30 rears
https://www.sau.com.au/forums/topic/336512-wide-r33-wheels/#findComment-5442489
their insane! just look at the size of that DISH! so where do I look at for a set of wheels?
https://www.sau.com.au/forums/topic/336512-wide-r33-wheels/#findComment-5442812
Hey mate,
I've got a GTS-4 which I put 30mm wider front guards and gtr rear quarters, I'm running 18x10 +18 on front and rears, the front sit nice and flush with the guards. But if your going 50mm wider at rear you will be able to run something like 18x12.
This is what my car looks like and for those following it all you see is spinning dish, but please forward pics of your car man I was going to build my car based on that same picture you've got there ;) I still want to do a Super-Gt style kit for my car down the track.
If your interested these wheels are Work Emotion XD9's, go to workwheelsaustralia and check out what they have if any are 18x12 to fill your guards.
https://www.sau.com.au/forums/topic/336512-wide-r33-wheels/#findComment-5445207
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
