I'm after a 2nd hand twin plate clutch (OS Giken, HKS, NISMO) for an rb20det. Prefer it as a kit with flywheel.
Also after an aftermarket dump and front pipe for rb20det. Something like a HKS dual dump and i'll get a front pipe made up.
I'm located on the Gold Coast and would prefer them in the next week or two (esp clutch).
cheers
Neil
https://www.sau.com.au/forums/topic/33690-twin-plate-clutch-and-twin-dump-pipe/
cheers
Neil
WE HAVE HEAPS OF TWINS TRIPLES AND QUAD CLUTCHES HERE BUD
WWW.OPTION1GARAGE.COM.AU
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
