so ive recently purchaced a gt3076r and now looking at the dist between the manifold and the strut tower it looks like it might not fit down there..
has anyone done this/will i need to get a new topmount manifold?
thanks Simon G
https://www.sau.com.au/forums/topic/337271-fitting-a-gt3076r-into-a-r32-rb25/
Above is correct. I got a 3076 with a 10pm spacer on stock manifold. Fits on my r33. Don't think the engine bay is smaller in the r32 but I could he wrong. I know I can fit a 3540 on my stock manifold so I think you should be fine
adriano.. rotate housings? is that just a unbolt slide it round rebolt? does it affect the flow? can anyone else confirm this? :)
rotate the exhaust housing so that the oil feed sits at the top when the turbo is bolted to the manifold then rotate the comp housing to suit your cooler piping
haha alrighty thanks guys thats a load off my mind so does anyone know of a trader on here that sells the 10mm T3 spacers and at what cost?
another q.. anyone know about oil and water lines for the 3076 wil they be the same as my Apexi 400hp thats on there atm?
mtq can get a spacer for you.
i did the exact same thing with my gt2876 .86 on my rb25. stock manifold. needed 2 spacers with extended hightensile studs though. mtq can supply all gaskets, lines and flangeplates you might need and for a very good price to.
Pics
Uploaded with ImageShack.us
Edited by Stargate
Also have the same turbo, but on a 33.
+1 for Mtq having tons of stuff that you will need.
Also, The lines may be different to the ones on your apexi:
1. your apexi turbo is a 400hp turbo, this is a 550-600hp turbo and probably bigger and you may need longer/shorter lines.
2. We dont know what your apexi and your 3076r turbos cores are, meaning the type of bearing used in them. If 1 is a ball bearing and one is a journal bearing, the ball bearing requires significantly less oil whereas the journal bearing needs lots of oil - this is important for you to know.
so it probably just easier to get some new lines and fittings, they are not that expensive, I bought mine at a place called pirtek.
gl with it.
Oh wow thats spooky i also has an Apexi 400hp turbo on mine before upgrading! I needed new lines
http://cgi.ebay.com.au/Turbo-Oil-Water-lin...=item41525113c6
should these lines suffice? it says single ball bearing on there tho im not 100% but i think its a dual BB (at work atm cnt go look at it)
also once ive got it bolted on with correct lines n spacers etc.. is it safe to drive it or will i need a retune? and for a tune is it going to be costly seeming as its just being retuned to the turbo or is a tune just a full tune? :D
Edited by simonthomasgoodwin
also once ive got it bolted on with correct lines n spacers etc.. is it safe to drive it or will i need a retune? and for a tune is it going to be costly seeming as its just being retuned to the turbo or is a tune just a full tune? :cool:
I would ring MTQ and order the lines and spacer all at once it wont be that expensive, I think it cost me about $200 and it all worked perfectly. You could probably drive it to a tune off boost but i wouldnt go further than that, and as for the retune mine was a little cheaper becasue they didnt have to do a lot to the lower rpm sections of the tune so it was a little cheaper than normal
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
