hey all
i just took my car out for a run through the nato park, soon as i went through the gates i pulled over to take a phone call, as the car was idling for afew mins, i could feel the revs slowly dropping, so i turned it off not thinking much of it.
restarted the car all was fine for another 30mins of non stop driving, then again same prob happened soon as im stopped idling and go to take off its like the engine wont rev at all, not missfiring, no nothing !
u have ur foot on the accelerator and it wont rev up ! sometimes it might kick back into life and the car boosts/idles perfectly again...
when this happens i have to quickly turn my car off, then restart it and away she goes all is good again
what can this be its driving me nuts !!
i had the car out last night and no such problem occured, and this morning i took my airflow meters off and cleaned them with some c02 contact cleaner. ive done this many times before so i dont no how this could have anything to do with it?
all AFm plugs are in tight, even checked the CAS connector and ignitior connector
any helpful info would be great !
thanks
https://www.sau.com.au/forums/topic/337371-r32-gtr-problem/
just disconnected the positive battery terminal pumped the brakes afew times and went for another drive, same thing, she doesnt like to idle at the lights and then to accelerate, without turning the ignition off and back on...
https://www.sau.com.au/forums/topic/337371-r32-gtr-problem/#findComment-5454305
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
