Ok, heres the deal.
My gtr is stalling on idle, spluttering etc only when warmed up.
Thought it to be a ECU issue with the power fc(Which when installed happens alot more frequent and worse) so i got the old ecu installed worked fine for a week.
Issue still exsists.
I have checked the Vac Lines and piping for leaks as far as i know there are no leaks.
I have cleaned the AFS with contact spray.
I have yet to check the Idle control unit.
I run a stock bov.
The car use to idle on 1200rpm however after issue only appeared after idle down to 9000/1000rpm from Godzilla after they fixed my timing to 20.
I have taken my car to Mercury and they did say it was either the Power fc or the wiring.
I got my stereo installed by WOW @ Underwood. Dodgy install dodgy products drivers side speaker blew and they tried to say i installed it myself (I Didnt)... anyways back on track when the car stalls it does not seem like it looses power the engine just dies could the wiring be stalling cutting ignition to the engine?
I have been told that it is a common fault with skylines that it does not return to idle very well. or that the altnerator does not charge correctly.
Can anyone help me?
https://www.sau.com.au/forums/topic/337754-help/
Sounds like an airflow meter to me, try swapping them one at a time for one you know works, While yours are now clean the fault could be on the solder inside it for example or like mine the wiring in the pug has come loose from the pins
https://www.sau.com.au/forums/topic/337754-help/#findComment-5459679
Thanks mate, Yeah im taking it to a Auto Sparky tomorrow to get him to have a look at it.
Cheers for the tip.
I thought it was the power fc looks like i can plug that back in :thumbsup: as soon as this is resolved lol.
https://www.sau.com.au/forums/topic/337754-help/#findComment-5459849
Wiring is fine, Suspecting a DEAD AFS. or its not earthing right, so tried some stuff and if that doesnt work new AFS will be coming.
Hey mate go to the ETC on your PFC hand controller and select sw/sensor - you will see o2.1 and o2.2 listed check what these are reading. They will be different but if one is way different to teh other tehn you can confirman AFM prblem.
https://www.sau.com.au/forums/topic/337754-help/#findComment-5462969
Can anyone help me?
lol. thats all i have to say to that claim.
So are you saying that after WOW installed your sound system, the car THEN went funky?
Can you give some advice as to how the events unfolded in chronological order?
I remember I had to adjust my idle thingy on the rb26 and all i can say is DONT take it off because it is a broad minded person to get back in. If you adjust it with a screwdriver, it may work for you, though I don't know if that is just a bandaid solution - still masking the original problem.
Jonnyo's postulation seems quite logical, if you dont have access to a multimeter - id give that a go first, since it is a non-invasive procedure.
Otherwise, good luck.
https://www.sau.com.au/forums/topic/337754-help/#findComment-5464932
When I first got my R33 a few years ago it used to hunt like mad and sometimes stall when pulling up to lights and stuff. I searched on here for similar problems and a few people managed to fix it after cleaning the idle air control valve. What happens is the spring inside gets all full of shit and doesnt open and close properly causing the car to hunt at idle. I took mine off and cleaned it all with carby cleaner and then adjusted the idle and that fixed the problem. Easy game.
https://www.sau.com.au/forums/topic/337754-help/#findComment-5478465
Here is the link to the guide I followed.
AAC Valve Cleaning Guide
This is done on an RB25 but there isn't too much difference between the two engines anyway.
Thanks, I just adjusted the idle and it hasnt not hunted since ;)
https://www.sau.com.au/forums/topic/337754-help/#findComment-5488011
if its still playing up re-install stock ecu and hook up a diagnostics tool to it, ask mercury or what ever shop u use, one should have one and it should be able to pull out a fault code, letting you know exactly the fault, my guess will be afm's most likely. very common problem, they just get old solder inside them and can be repaired, but most people exchange them or buy new ones at great expense. butr could be another issue with iac aswell? try them all, just go to the diy section and start searching for HOW TO: threads. its a process of elimination with skylines.especially when it comes to sensor problems, some or many may lead to the same out come, its just trying to find the correct one which is a bitch.
https://www.sau.com.au/forums/topic/337754-help/#findComment-5495047
  • 2 months later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
