Hi all,
I'm a newbie here just bought my 01 v35 sedan few weeks back. I was thinking to go for a wheel upgrade and was looking at few 19"s. Could anyone please tell me what is the preferred widths and offsets (front & rear) i should be looking for if i don't want to lose much ride comfort and don't want to do any cutting or expensive body work.
I am hopping to lower my car with 350z springs in the future so should i consider that when I look for wheels as well? And where can i buy the 350z springs from? Nissan dealer or?
sorry guys if these topics are posted before tried to find but couldn't find much information. Any help would be much appreciated >_<
Cheers,
Raween
https://www.sau.com.au/forums/topic/337869-upgrading-to-19-wheels/
Thanks Nismo.. they were nice wheels but not just the look im looking for. Just wondering when you had them in the car did you have to roll the fenders and everything? or was is just put em on and drive? And how was the ride comfort compared to the stock 17"s?
Cheers
Cheers
I had 19s on mine, didn't have to roll and fenders or anything like that, simply put em on and they were the perfect offsets.
I used King Springs from Fulcrum Suspensions for a 350z coupe, lowered the car around an inch which was enough to tuck the rear wheels inside the arch.
The wheel specs were: Front 19" x 8.5" +38, Rear 19" x 9.5" +45, checkout the pics and you'll see how good it looks.
Thanks a lot for the info and the pictures goldv35 really appreciate it.. :laugh:
Just wondering how was the ride comfort with 19"s plus lowered springs? was it a big difference or ?
Cheers
Thanks a lot for the info and the pictures goldv35 really appreciate it.. :blink:
Cheers
Well the springs were rated as 15% stiffer than stock and the tyres are obviously lower profile so there is some loss of smoothness/comfort on rough roads.
This is offset by the handling being more responsive and 'sporty', and looking good of course.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
