ok so i've decided to keep my laurel and use it for a streeter for a while , atm it's running a rb20 with a hks 2530, gtr injectors , z32 , pfc and all the other supporting mods , not being happy with the off boost characteristics i decided to buy a rb25 to slap in the lil 20's place (being a daily driven car , on the street lag can get effing annoying) . Now, before i start pulling it apart, i want to get the complete setup organised so it gets put back together as quickly as possible, so heres a few questions i'd like y'all to give me some input on:
1.) is it possible to use the gtr injectors? , if not , high flowed std injectors?
2.) would the hks 2530 be too small for an rb25 , if so , do you have any other suggestions (keep in mind i'm not after any power figure , just good response/torque)
3.) is the ap engineering pfc adaptable to rb25? (i do have a z32 ecu laying about ready for a nistune board if not)
4.) would a forward facing plenum be worth the cost for this type of setup?
5.) exhaust manifolds , is there any advantage to aftermarket types for lower powered rb25?
6.) is it worth looking for a larger size throttle body?
if there's anything you think i may have missed , feel free to post up . thanks :) (please note: the reason i'm not aiming for big power is because i have a track car to do that with , which is why i'm kinda trying to convert this one as cheap as possible)
if there's anything you think i may have missed , feel free to post up . thanks ;) (please note: the reason i'm not aiming for big power is because i have a track car to do that with , which is why i'm kinda trying to convert this one as cheap as possible)
ok , i spoke with my tuner today and got the answers i needed , incase someone searches for this i'll put up the answers:
1.) no , tightarse, sell them and buy s15(?) 480cc injectors
2.) .64 rear housing (i think it would be) = too small really , i'd be wheezy up top
3.) in short , yes
4.) not if your a tightarse
5.) not with the 2530
6.) i forgot to ask this question :D
It seems if your going to the trouble of RB20 to RB 25, show a bit more "mongrel". After swapping a whole engine go for a better turbo and supporting systems, otherwise just hop up the RB20.
i probably will , the only reason i origionally didn't want to is because i'm building another car with a rb25 t67 and supporting mods , my aim for this car was basically to make it a fun streeter so minimal lag is important :D , i can't think of a better turbo to use for that exact purpose, i'm open to suggestions!
put the 2530 on it and see how it goes. it will give great responce which is what your after. yer sure it'll have f**k all top end and wont make huge power but thats not what your after by the sounds of it. if you dont like it then you can easily remove it and upgrade to something bigger.
as for 6, leave the standard t/b on there with the standard plenum etc
Gt 30/71 or Gt30/76 a little madder and GT 35, or leave in the RB20
gt30 or 35 wouldn't give me the response i'm looking for :D , great turbo's but
yeah that seems like the go , i've searched round these forums a bit but haven't found the answers i'm looking for in reg to turbo sizing , i spend most of my time between 2500rpm and 5000rpm , the problem with the lil rb20 isn't the amount of power it makes but how long it takes to come on full boost (arond 4000rpm i think , pretty similar to my other car when it had a kkr430 strapped to its rb20) . It's my daily atm and i keep catching myself off boost when i really don't want to be, my last daily was a ba xr8 ute so i'm kinds used to large displacement engines too, i don't want/need any more than 200rwk really as i'd only get myself into trouble and a std 25 turbo is smaller afaik , what i'm hoping for is stock like response with a little more mid range :P
as for the tb , yeah , probably too much effort for little - if any gain :)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
