Up for sale is a 1996 Series 2 R33 GTST which was written off early September
Car can be used for parts.
Parts which survived the crash:
Rb25det Engine with manifold and turbo
Rb25det Gearbox
LSD
Front Headlights
Front Bumper
Rear Bumper with Pods
Rear Boot with GTR wing (will be sold seperately)
3inch Apexi Catback (will be sold seperately)
2 Rear Wheels 17 (front 2 might be buckled but not 100% sure)
Instrument Cluster (looks undamaged but not 100% sure)
Thats all parts i can think of on top of my head.
Looking For $2450 ono
Car is located in Clayton Melbourne pick up available or can arrange tow at buyers expense
Contact me: 0412357245, PM or MSN: [email protected]
Cheers
Johnson
Edited by Bayside Blue R34 GTV
https://www.sau.com.au/forums/topic/338313-wrecked-r33-gtst/
Rb25det Gearbox
LSD
Front Headlights
Front Bumper
Cheers
Johnson
3inch Apexi Catback $380 Sounds real nice, not drony at all minor scratch & dent
Boot Lid with GTR wing $280
will post pics tomorrow
By the way guys not really looking forward to part the rest of the car as its too much hassel.
F/S is the whole car as it is with no catback and bootlid
thanks
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
