changed to another 2nd hand alternator and no luck....
is there a way i can test the alternator of the car? i could have just bought another dud alternator....but want to be able to rule it out...
Hi all,
i fitted a brand new battery this morning, turned her over and all was fine.
not 30 minutes later i tried to start it again and it was flat.....clutch started it and drove off. about 10 minutes down the road the car started to choke....the revs began to bounce and within 30 seconds the car cut out.....i pulled over and tried to crank it.....flat.
i pulled out a charged battery and jumped started it.....disconnected the jumper.....and fine for 20 seconds......then revs started to bounce again....then cut out again....
i swapped the batteries....and the she started fine and ran ok......i then disconnected the battery as i didnt want it to drain again......i was then able to drive the car for 10 minutes home....
i noticed on the way home that the battery light in the dash was on.....firstly what does that light mean? and what do you think i am faced with?
im thinking alternator is cactus....but why?? nothing has changed since i drove it last....
also i just changed front bar....could the fog lights, even tho they are visibly off, somehow be on and sucking power? nothing else has changed....
list of things i need answered...
1. what does the battery light in dash mean?
2. could it be my alternator?
3. how hard is it to change an alternator?
4. fog lights?
thanks guys!!
where is u locate..? if u near by me i will come and have a look. if u like. let me know any way
  • 1 month later...
  • 3 months later...
  • 1 month later...
  • 1 month later...
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
