Im ready to get my car tuned, found 4B Action at cardiff nsw who are a nistune agent. Quoted $1100 for them to send ecu to nistune to fit daughter board, and full tune. Is this reasonable? Anyone dealt with them?
I need a bigger fuel pump and injectors. What fuel pump do i need to fit to a s2 neo stagea , where to buy it and how much should i pay?
Ill probably go with seimens 650 cc injectors.
Advice please guys.
Advice please guys.
I have the same car, fitted with nistune.
I recently put the walbro gss342 in mine, fitted straight in. http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=180533428704
They are tricky boards to fit, i had mine done locally but it needs to be done by an expert with the right gear.
A cheaper option may be to send your ecu directly to matt had get him to fit it for you, and then get them to tune it.
That listing doesnt cover the type 4 board, which the OP has. Matt will fit and supply the board. Board is 260, fitting is 60
**EDIT**
Type 4 board, same seller/tuner http://cgi.ebay.com.au/NISTUNE-TYPE-3-4-IN...=item2c56c7df1c
Edited by kjb_r33
$1100 is what a lot of tuners charge. there are some cheaper though. it really comes down to how much you trust the local guy. if you trust him to do a good job then it is worth paying the extra money to get it done locally, that way if something goes wrong you can take it back there easily to get it sorted.
I sold my 300zx to a guy in the hunter, 4B is almost the only one listed in newcastle for tuning the Nistune. I gave the guy their contact details, they tuned his car and he was very happy with it.
By all accounts he was pretty thorough, but i have had no first hand experience with them.
$1100 is about the norm but I'd be making sure you get a Single User license for the Nistune software with that...
Board - ~$260
Fitting - $beer (I have a mate that does the soldering for me)
Single user license - $200
Tuning - $400-500 (~4hrs on dyno @ 100-120/hr)
Total - ~$1000
OR
Buy the board yourself direct from NIStune, find someone to fit it, then just pay the tuners tuning costs.
so it seems fair, the shop is only 2 minutes away so that makes everything simple. when i get the board fitted to my ecu can i drive the car to the shop with bigger injectors and a z32 afm? what impedence injectors do i need?
No, the k multiplier will need to be changed for injectors and the AFM. the standard injectors are standard resistance, the seimens are fine, no resistor needed.
If you have a User license for the software you can go in and use the inbuilt tool to change AFM and injector size, this should get you close enough to drive it to the workshop (just don't boost it up).
you can ask matt from nistune, or whoever is doing your board, to have the board ready for z32 afm, and whatever size injectors you're putting in. then the car will start and run to get you to the dyno.
Edited by Munkyb0y
exactly. you can have them set up the ecu so that you can put the afm and injectors in while the board is being done, then when you get the ecu back, just plug it in and it will drive fine.
I still wouldn't load it right up until it's been tuned though. The inbuilt tool for changing the afm and injectors comes close but odds are things still need to be massaged to be running spot on.
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
