Bought these off a forum member but they will not adapt to what i had in mind for them
http://www.nengun.com/garage-defend/stingray
they are in good condition and designed to fit standard front bumper
450 dollars plus postage
ph. 0413 863207
  • Nope 24
https://www.sau.com.au/forums/topic/339081-garage-defend-front-canrds-34-gtr/
  • 1 month later...
hay buddy
what ill do is when i get home (and it stops fkn raining) ill measure the gap where they would sit in the opening of the front bar. if u could please measure the gap from the front section of the canard top to bottom i could better guage the physical size of the thing.
ill also speak to my mate shane from psi parts and see if we could modify them and remake them again in carbon
thanks dude
Not sure I know where you mean but the front section that wraps around is what i measured.
The outside measurement is 21 centimetres and the inside is 17 centimetres.
  • Nope 24
  • 3 weeks later...
are they universal?will this fit to any r33,33,34 and silvia bumpers? cheers
http://www.nengun.co...defend/stingray
ph. 0413 863207
  • 3 weeks later...
hay buddy
thanks dude
Reproducing these in wet carbon fibre would not be hard at all. The trickest part would be making up the molds -
1) waxing component to be copied with several layers of special wax
2) coating with tooling gelcoat
3) applying poly resin and reinforce with fibreglass mash
4) repeat step 3 until a thick enough layer is built up
5) wait until cured and 'pop' it out
Once the mold is made, you can make copies of the part by using carbon fibre fabric, you could even use carbon-kevlar or even kevlar on its own depending on the look youre after.
The trick is not to stirr up the resin too much when mixing in the hardener (Methyl ethyl ketone peroxide - MEKP) - this creates bubbles and you dont want bubbles appearing all over the top of the layer of carbon fibre.
I've made up many carbon parts by using this technique.
Anyways, hope that helps.
  • 1 month later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
