Im having to sell my stag due to changes in the road laws in SA, therefore im no longer able to drive it. Sucks balls but not much i can do about it.
As the pics show, white series 2 RS4, very good condition, 93,XXX km, first australian owner after import, originally paid 17,500 for it, only been driven a few hundred KM's in aus.
Sequential auto with button shift on steering wheel
full CATBACK exhaust system
HKS mushroom filter
professionally fitted alarm/immobiliser
genuine stagea plush mats
cargo net and cover
DAYZ body kit
Kenwood Z/X-909 CD/Tape deck
4" exhaust tip
Twin sunroof
Original manuals and service history from japan
Im looking for around 15,000 but thats negotiable. More pics are available if any1 wants them.
Edited by Impaledskull
https://www.sau.com.au/forums/topic/339163-wc34-stagea-series-2-rs4-sale/
  • 3 weeks later...
Dam Bro, if only you were in Melbourne and interested in a R34, i would of loved to swap you :)
Its exactly what im after atm. Newaiz Good Luck with the Sales Mate :ninja:
Btw u can check out my ride on this link
http://www.skylinesaustralia.com/forums/Eo...l&hl=stagea
  • 1 month later...
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
