http://www.nengun.com/auction/item/v163900055
Pretty much want my interior to look like the above how does it work etc ?
say if i was to buy it do they just get thrown over or ?
Also i have abs bags behind my drivers and passengers seat i had a hard time throwing over seat covers as they just don't fit :\
theyre fitted throw overs, not universal throw overs, so they work a bit better, but you would need the same seats etc as the ones they are suited for.
ebay sells fitted leather throw overs to suite different cars, give them a look
hey mate,
You can try proseat http://www.proseat.com.au/testing/Nissan_R33_GTST_1.html they are based in Victoria. :thanks: came across them on ebay. They do front two seats and back seat for 570$ and free door trims and gearbox surroundings. That's what they quoted me on a r33 :D. Let me know if you get them done.. post some picture :thumbsup:
they look good from the pics, but i just got this feeling that they might be loose and similar to a universal seat cover :whistling:
id like to get some feedback from someone who actually has them
I went for ultimate auto trim in my R33 GTST. http://www.ultimateautotrim.com/
professional service. and the product has been great (been in over a year now, no problems).
I paid $900 (delivered to WA) for the full car option. front and rear seats, black and ivory colour combination, gear boot, handbrake, centre console cover, door panels, and rear speaker panel.
For the seats its essentially a perfectly fitted cover (matched to the R33 seat) that you then stitch onto the seat (easy job, just pulling about 8-12 cords through the seat to secure the cover)
Edited by jjman
wait... you stitch them to the seats?
wouldnt that wreck the original seats?
Seen jjman's Interior and it looks Awesome.
+1
Edited by SL33K
+1 for ultimate auto trim
i got full set for my 32
they have auctions on ebay starting at 99c occasionally
i got a full set with rear parcel shelf, door trims and centre console lid for $500
http://cgi.ebay.com.au/SEAT-COVER-NISSAN-S...=item4cf2c18de2
thats one thats up to 150
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
