Free BUMP, i have these on my R33, they are sensational. Great clear light, some of the best non-factory HIDs i've ever seen. Do not dazzle oncoming drivers ever. These are a steal at this price!!!!!!
Not being silly but the add doesn't state the brand.. So how do you know which ones they are??
