Preamble
This thread aims to help a few of you guys understand what HIDs are, how they work, and why the use of projectors is pretty much a necessity.
I'll attempt to explain how the bulbs are illuminated, what each part in a basic assembly does and the various colors that are available.
What are HIDs?
HIDs (High Intensity Discharge) are a bright-shining, low-voltage light globe with a rather aesthetically appealing glow. When most people think of HIDs, they think of those annoying, bright, blue headlights.
HIDs can actually come in other colors, such as purples, yellows, orange, green, etc.
A HID globe looks like this;
Non-HID is on the left.
* PHOTO COMING LATER *
Please refer to the following picture for reference about the voltage VS color side of things.
How do they work?
HIDs work by passing a current through a compressed gas. For those who did physics at school, and studied CRTs, you'd have witnessed excited atoms in a vacuum, HIDs work with the same theory.
What happens, is the energy from the electrical current excites the particles within the vacuumed HID bulb. These excited particles begin to glow.
This glow is rather bright, and it doesn't draw as much power from your cars electrical system as a conventional bulb would. So by using HID bulbs, you're effectively reducing the amount of electrical energy drawn from your battery, and gaining better visibility.
Some of you smarter cookies will now realize that if these bulbs run off a lower voltage, how is this regulated?
When you install a HID, you'll plug the bulb into a ballast, and said ballast into the cars eletrical system (to replace the old globe).
The ballast limits the amount of power going to the bulb, effectively working as a step-down transformer, except it doesn't generate a tremendous amount of heat (in my experience).
How does a standard setup look? (No projector)
I'm just focussing on the wiring here.
A simple, basic setup goes...
BATTERY -> Ballast
BALLAST -> HID
What are Projectors?
Projectors are enclosures which you put your HIDs into before replacing your standard globes. The main features of the HID are the lense and internal light-wave reflection.
Refer to the diagram
What this basically means, is that light waves won't be shone into the eyes of oncoming traffic, and noone get's blinded.
As you can see, the only lightwaves that aren't cut off by the cut-off shield are the ones that would be refracted through the lense, up into the eyes of oncoming traffic. The lightwaves that do pass are reflect back down onto the road. This increases visibility as well, so it's not totally a selfless act :ermm:
Simple write up I might update after reading over it tomorrow / the next day.
I'll do photos later.
Inspired by this post.
If you feel i've got something wrong, please feel free to comment and I'll have a look at it. Sort of went by common sense/basic physics for the majority of this.
https://www.sau.com.au/forums/topic/339646-the-hid-thread/
ok so after having a good read im still a little confused.. my headlights are the black jdm "shark eye" types (pictured) all the "blue/white" halogen bulbs i've tried in the past are complete shit, they just colour the outer lens a light blue but the actual shine is still pretty yellow.. very minimal difference over standard bulbs.
i would probably go for 4300k or 6000k.. what exactly would i need to do to my headlights so they dont cause glare etc?
https://www.sau.com.au/forums/topic/339646-the-hid-thread/#findComment-5487400
Get in on this lol
http://www.skylinesaustralia.com/forums/Cu...re-t334490.html
Actually that is quite incorrect.
HID's run off a hell of a lot more voltage, not lower. On start up a typical HID ballast will output 18,000-24,000V (18-24kV) for up to 30 seconds (this is called the warm up time). Once they are at operating temperature a ballast will output around 85V.
What you ment to say is HID's use less power (Typically 35W) P=VI
Just thought I would add to this aswell so people don't get confused. A projector used for a halogen bulb is not the same as a projector used for a HID bulb. While a halogen bulb projector does work better with a HID bulb over a reflector, it is still not perfect. This is the reason why in the glass headlights we are designing with Spinto we are using Bosch projectors made for HID bulbs so there is a perfect focal point and cut off.
Edited by PM-R33
https://www.sau.com.au/forums/topic/339646-the-hid-thread/#findComment-5487661
ok well that doesnt help me much for 2 reasons
1. i have an R32
2. very much out of my price range at the moment
i've found a few HID kits that are much more in my price range, but i dont want to install it then find it causes glare all over the place. i've read that you can play around with the adjustments on the headlight and cut down on that.. has anyone here done that with any success?
https://www.sau.com.au/forums/topic/339646-the-hid-thread/#findComment-5489050
Ahh see I was going by what I had been told from friends. Thanks for clearing that up, I'll append OP accordingly.
Didn't know that either, thanks. I'll add that to OP as well.
Thanks for the input :( I really appreciate it.
edit; They're preventing me from editting it... that's bullshit..
Edited by SKITTLES
https://www.sau.com.au/forums/topic/339646-the-hid-thread/#findComment-5491997
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
