  • Replies 106
has anyone got any shitty old rims laying about i can borrow and/or buy to use for cheeseys? that would fit my 32 GTR? dont need to have tyres on them. cheers!
got a pair of territory rims u could borrow, Damo
Hey Peeps,
I haven't been on this site in a LONG while but thought I'd open up a new account.. I used to own GTR001 which I sold to Damo on here !!
I have just recently brought another R32 GTR from NSW and I get it Friday morning and am contemplating whether to enter it for a bit of fun next Saturday at Powercruise but don't have a great amount of knowledge on the event ot time as I only get the car the morning before Powercruise :blink:
Firstly what do I need my car to be prepped with to enter ?
What do I need to have ? Helmet etc ?
Also it will still have plates from NSW on it ? Will that be a problem ?
Also what does it cost to enter ?
What time does it open for cars ?
Also what event is there in the way of racing ? (On track street racing :blush:)
Any help would be sweet !!
Cheers
Tenille
Hey Peeps,
Cheers
Tenille
well this event is based on street cars so its based as a run what you brung event with the requirment of the car being road legal. Mainly just no fluid leaks.
Personly flogging a r32 gtr as soon as you get it allways going to end in tears. Im pretty sure 80% of the people on here have either blown up or crashed a r32 with in the week of getting it or know some one who has. They are considered a fragile car untill you have a good check over them.
i think the entry this close to the event is about 260 bux. But all then info you have asked for is on there web site.
welcome back tenille :wave: just take into account what the other damo has said and check ure new machine out thoroughly and take it easy on her, see you down there. Damo
Totally agree guys, I'v actually put buying the car on hold for a few weeks as I have just been put off at work for a while >_<
But I'm still coming a look on Saturday though, look forward to seeing GTR001 again Damo :blush: Miss that car like hell !!
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
