On 20/06/2020 at 8:31 PM, Cam-party-m35stagea said:
Hey guys I had this same issue on my m35 stagea
basically undo the two covers that protect the vtc on the front of the motor, Then carefully unplug the “blue plugs” adapter behind the cover.
There will be a solenoid sitting in the case you remove just slotted in by 2 pins.
swap both solenoids over with eachother, then put them back on.
if you want clean out the casing and the little oil hole which you’ll clearly see on the inside of the cone shaped support housing for the solenoid.
I also degreased the inside of the solenoid by removing the little grommet at the base of the wiring on the solenoid and blew it out.
anyway, swap them over, if the noise changes sides you know all the rest of the bullshit the squinyon mechanics are telling you to swap in not necessary.
Also I did check the cam for movement by putting a spanner on the end of the cam, you should be able to twist it to tension the spring... when you turn it the right way push a little harder and it will lock into the safe lock and stop it in a position that you can’t move without oil pressure. But anyway lock it like I explained above and put her back together.
once you pull the covers off it’s very straight forward and would take any dumb c**t no longer than ten minutes to do.
Mine luckily fixed the terrible knock that started at about 2k revs.
hope it makes sense. I cbfed reading the novel I wrote so good luck.
If this works for me also we should sticky
  • 1 month later...
On 27/04/2014 at 9:52 AM, scotty nm35 said:
It's not the timing chain, it is usually caused by the cvt actuator assembly. I have replaced a few now with s/h assemblies and fixed the noise.
Who diagnosed it to the chain anyway?
Hey Scott, can you have a look at my car. I tried to PM’d you but it’s not sending. Apparently you’re not receiving PM message at the moment. Can you PM  your address. I’m from SE Melbourne. Thanks in advance.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
