Thanks to scott bringing his 13 around the other night i've been inspired to get my 33 back on the road in the next week...she's basically complete...looking brand new again in complete standard form....just have a slight issue with my ECU
If anyone has a S2 R33 Standard Computer lying around that i could borrow for a couple of weeks to get through regency that would be greatly appreciated..ill come and pick it up...give you some beer or something for the troubles...
also.....how strict are they on child restrains these days? Car is in completely original condition with every nut/bolt/plug/hose/pipe where it should be...what are my chances of getting through? I've been out of the car scene for a little bit now gimme a break :banana:
cheers guys
Ryan.
https://www.sau.com.au/forums/topic/340319-hey-guys/
I've noticed they pay alot of attention to the underside of the car - most probably because theres a better chance at finding something like worn bushing to knock people back with if everything else in the engine bay is standard.
https://www.sau.com.au/forums/topic/340319-hey-guys/#findComment-5495176
also.....how strict are they on child restrains these days? Car is in completely original condition with every nut/bolt/plug/hose/pipe where it should be...what are my chances of getting through? I've been out of the car scene for a little bit now gimme a break :)
cheers guys
Ryan.
holy shit! your back!! :D good luck getting her thru mate
https://www.sau.com.au/forums/topic/340319-hey-guys/#findComment-5497701
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
