I don't have one - but kept help but be interested - what does a Jenesis rear bar look like? Can you post a picture?
This is an Jenesis FRP Rear Bar. It's only a cover, as it needs the original S2 bumper to support it.
And Steve, You were looking for rocking horse poo before when trying to get an N/S/F DR guard, what would you describe this request?
D
By off chance does anyone have a FRP Jenesis bumper laying about they want to sell and wouldnt mind sending to WA?
Cheers,
Steve
By off chance ummmmmmmmmmmmmmmmmmmmmmmmmmmmm, mmmmmmmmmmmmmmmmmmmmmmmaybe!
I don't have the rear bar you are talking about specifically and you do know that it is 50000 yen plus freight & add ons new?
Buuuuuuuuuuut, I do have these! And I have the JDM rear bar to go inside it.
Cheers, D :P
I didn't use it due to the skirts problem initially, but now that I have 2 PNV Skylines, the whole thing would be a bit gawdy IMHO, so my modified version is just going to use the Iron Mask body kit. The track car doesn't matter about looks that much, so long as it's effective.
D
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
