i predict close to 4k if not just over for the c210.
17 bidders holy shit!
With 6 days to go, I don't know why everyone is bidding so early...
The video provides a reasonable idea of the condition of the car - much better than a few photos.
JH
JH
weeds out the time wasters and gives you an idea of whether or not its in a realistic price range (i always bid up to the reserve to see what it is, and it ticked over once i bid 2500), its auction sniper time now.
It'll be interesting to watch. Just checked the location, just over the border near Mildura. Nice dry climate.
JH
It's the zero feedback newbies that I'm always wary about on these auctions?
How easy would it be for the seller to organise to boost the price a little and how often do you see the newbie has sent the price through the roof, yet it gets re listed due to non paying bidder?
D
...(i always bid up to the reserve to see what it is, and it ticked over once i bid 2500), its auction sniper time now.
Very weird auction, the price is now $2425 which is below the $2500 you bid up to. A higher bidder retracted on the grounds that the 'description changed' and it looks like the price wound back to below the reserve.
Have you seen the car in person? In the new pics it looks like there's rust in the gutter near the antenna.
Is it correct that these engines aren't suited to unleaded fuel? I thought they were basically the same as the R30 engine.
JH
JH
The seller canceled all of the zero feedback newbey bids because he couldn't be contacted. As I said it d!ckheads on these auctions that boost the value and have no intention of buying.
That's why the price is down, although as you said John, STATUS has allegedly bid $2500.00 which isn't there.
Having said that he is going to sniper bid it next and he has the advantage of knowing the reserve.
Good position to be in if you're a serious contender.
Just take your snorkel and flippers when picking it up, as all major highways were cut into Mildura yesterday.
Cheers, D
yeah i sniped it @ 3960 about 5 days back but when it went to snipe with 5 secs to go it was too low and lost. I had an initial bid of 2500 which cleared the reserve.
I was not willing to pay over 3960, so good luck to the high bidder hopefully it is as good as the description.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
