Lol pretty sure youve had your threads lock a few times before for same reason hahaha
blitz will be all over this soon...
You are either stupid or ignorant.
Either way you've been told VERY CLEARLY before not to post up this shit.
Go and read your past threads.
Start another thread without paying trader fees & reading the rules, you will be banned.
-Admin.
