Ok what we have here is a R32 GTR rolling shell with full interior all panels and glass complied registered.
Originally I planed on removing the ABS, air con and manual gearbox, stripping the engine bay and re spraying and putting my complete set up in with all wiring hidden and full auto but have since lost interest. All I got up to was stripping the bay, welding majority of holes and high fill. The ECU runs a Map sensor so the original air flow meter plugs have been cut off the loom :P, but the rest of the full loom is there, boot cable is broken so will not release form in car but fuel release works fine, also rust under paint on driver door bout the size of 20 cent piece
So heres what you do and don’t get,
DOES NOT INCLUDE
Engine
Gearbox (can supply R33 GTR box with blown 3rd gear)
Intercooler
COMES WITH THE FOLLOWING BUT NOT FITTED
ABS unit or front brake lines
All A/C components (may be hard to fit as lines to heater box have been cut with hacksaw)
Brake booster and master
Clutch booster and master
Rear Diff fully reconditioned new bearings seals
Blitz blow off valves X2
HKS super dragger exhaust cat back
All front guards lights, front bar everything missing from pics 3 & 4
Paint (for engine bay)
COMES WITH THE FOLLOWING FITTED
R32 GTR wheels with Re55 semi slicks
All Brakes
RDA slotted discs
QFM K750 pads
HKS hypermax II coil overs
Autronic SM4
CDI 500R
Advan surge tank
Bosch 040 in tank pump
Bosch 044 ex pump X2
Supporting Fuel lines
Hi cas lock bar
Battery in the boot
All interior in pretty good condition apart from usual bubble in dash.
Feel free to PM me anytime with any question or queries, any photos just send email address and I will forward them.
also note im possibly willing to separate some parts if the person buying does not require them, BUT the interior and body panels will NOT be pulled apart.
Cheers
located north/west suburbs Victoria
$12000ono
Please do not tell me you can get a complete running GTR for 15,000 im not interested.
https://www.sau.com.au/forums/topic/340951-r32-gtr-rolling-shell/
Someone could buy this, buy my engine and box and vola gtr for the win!!
good luck with the sale mate, if i had the money i'd be doing exactly what i said above!
sounds like a plan although i will have a complete engine for sale later next month as well that was built for this car.
if u split im interested in the wheels with the re55s....how much tread on those??
cheers.
will keep posted about the wheels although i would prefer to sell them with the car as then it wouldn't be a rolling shell.
and to all the people asking bout the fuel set up if i do end up separating it i will post it on another page separately so we can go from there.
but at present i am not separating anything just yet.
cheers
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
