I have R33 RB25DET and am having problems with the tacho. everything else works fine and i have tried cleaning out the pugs and checking the contacts. where to go from here? used to work intermittently but has total shit the tin now. i didnt have the problem when it went to red line it just dropped in and out when it wanted too. Any info on this would be greatly appreciated.
https://www.sau.com.au/forums/topic/341861-r33-tacho-head-fk/
I would almost put money on it being dry solder joints in the tacho. Same thing happened to the speedo on my old 33. If youre brave, you can pull the tacho out of the cluster and resolder all the joints and it should come back to life.
cheers guys fro all the help. i have mangaed to get it workin again but only every now and then. if i smash the upper rhs of the gauge cluster it comes to life. checked the signal input and 100% ok so probably gunna try and re-solder contacts! hey whats the worst that can happen ill just get another one if i f#@k it up!
  • 1 month later...
I have the same problem with the tach even after removing it, and blowing it out with canned air, though I neglected to spray the necessary contact points with the appropriate stuff so I will revisit it again one day.
Anyway, I have a simple solution and you don't need to do much. Gently pull on the trip odometer reset stalk (don't yank or pull too hard, ouch) until it works again. It probably won't be cured until the tach is thoroughly cleaned though, as the stalk pulling is a temporary fix.
I replaced my cluster, tacho was reading all over the place like jumping up and down to 5000rpm at idle.
If banging it temporarily fixes then it's as simple as a dry solder joint like other people have mentioned, you can either do it yourself or take it to auto electrician to refurbish.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
