Project Mu make factory pad sizes in several types of friction material compounds. their 2 piece rotors ARE exy, but well worth it
ive combined RDA slotted rotors with project mu pads (NR and NS) and they were effing awesome. so much so that ive done it again with my stagea. i hope they arrive next week!
+1 for RDA slotted rotors! They are awesome - was a bit tight on cash when I needed new pads so I opted for Ferrodo Thermoquiets (front) and Ferrodo DS3000 (rear) and was extremely surprised at how good they were. Would still like to put on Project Mu's but will have to wait till I need em changed ;)
I did a track day with the RDAs and found em to be pretty good. Don't think you need to go cross-drilled / bigger calipers - 4 pots are more than enough for the street.
Good luck!
Edited by diabolique
when they were hot the NRs made some noises, and dust was a bit of an issue. but they bit hard every time. this was on my S15s. they didnt squeal if thats what youre worried about?
This time ive gone for a lower temp pad because i wont be pushing the stagea as hard. there is a local seller too which is handy. Prices are pretty good IMO.
www.project-mu.com.au
if youre sticking with stock rotors, the series two V35s have larger brakes.
no i dont work there lol
Cool. I will look into those as well. As long as they don't squeal, it should be ok.
Thanks for the information, mate. I will post up when I made my choice.
Good luck!
Thanks Tarun.
Looks like RDA's are a good choice for many import owners. :)
$59 brembo's, if u just want the look. I was thinking about getting white ones but the look on my mechanics face when he would see them at my next service put me off.
http://cgi.ebay.com/ebaymotors/Infiniti-G3...=item230b0f2175
rofl. lmao
It's good for the looks.
But nah, I think I will pass this idea. :ermm:
Had some covers on my car were fine for daily driving
one trip to the track caused them to melt lol so I pulled them off
About RDA rotors I had them on my car but they cracked on me after one track day
Ferodo DS2500 pads FTW however be carefull with them if you have VDC on at the track as they can chew through a rotor if VDC keeps grabbing one of your discs
Thanks for the info, mate.
I am not tracking my V so won't be having those problems. So you use Ferodo DS2500 pads with RDA rotors and stock calipers?
+1 on the Ferodo or Benidix, i had both and they are really good on with the non brembo stock calipers. As for the red look just go buy a can of caliper paint from supercheap auto and paint them any color you want
I had RDA with stocko pads however after a trip to the track the pads were gone "were replaced by nissan only 15k before the track day" and the RDAs cracked
now using DBA4000 slotted/heat treated with Ferodo DS2500 on the front, DBA blanks on the rear with Hawk ceramic pads also had my fluid flushed with MOTUL RBF 600 FACTORY LINE, using stock calipers.
Iv had no issues with this set up on the street. They work great on the track "much better pedal feel/no fade" however make sure you turn VDC off otherwise you will end up chewing the front left disc if your doing lots of high speed right hand turns and the reverse if your doing high speed left hand turns at the track
The sprint sessions I do at Queensland raceway are only 5 or 6 laps so the stocko calipers do the job just fine with the better pads/discs. However if I was doing more than 10 laps there may be a need to upgrade as I think eventualy the heat would get too much for the non brembo sized discs/calipers
Edited by 180 wanabe
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
