for newer cars i'd be more inclined to say that mid year is the best time to buy as you will get people selling cars to get a new one as a tax write off. round xmas time people are more concerned about buying presents, etc, so a lot of people won't bother too much about selling their car, however at the same time you might get a few people who are desperate to sell to pay for xmas presents, LOL.
hahahaha, thats what I kind of thought.
Ok lads,
So today I went out and finally bought an FPV F6!!!
I went for a newer model, 2009 FG F6 Gun metal grey! it has 17,000kms on the clock and looks unreal...
Once i take delivery i will put a few pics up, very very happy with purchase!! ARHHHH... i can't believe it.
Ok lads,
Nice work, photos please!
Surely you've already put in an order for full exhaust, some injectors and a fuel pump plus tune for a nice easy 300 rwkw+?? They're a great platform.
The problem with the GT is that until Ford put a ridiculous amount of power into the thing, or shed a ridiculous amount of weight, and properly seperate it from the rest of the product range as a true flagship...it will never be a shadow of the original GT (or HO). 12.9, is nice, but compared to the rest of the FPV and HSV offerings, nothing really special. A flagship GT that would have EVERYONE talking would IMO be capable of a low to flat 12 from the showroom.
Although not the same far reaching heritage as the gt or gtho namesake; the hsv gts is now merely a clubby r8, not a real gts as previously the gts of the lineup had a different motor and early on different boxes (4 bolt main/grp a block, aussie stroker motor, hrt blueprint stroker, callaway built ls1)
Ford releasing a factory blown gt trumps hsv trying to pass off a fake gts so they can tell customers that their current ones are cheaper than previous gen ones..
Sorry.. Its something that really irks me for some reason, and ive previously owned a commo and a hsv, never a ford
Ok lads,
Fantastic.
Pics, stat!
Sorry for the hijack.. Good choice in car dude, gun metal f6 cant go wrong
Is it auto or manual?
I Bought the Auto, test drove the manual as well... thought the Auto gearbox was way better quality, no clunking sounds..:thumbsup:
you don't really even need to change the exhaust.
so why do they say 310kw??? fly wheel
Fkc im a noob... fly wheel my fcking bad.. hahahhaah so how many at the wheels do you guys reckon 270?
Edited by macdog
very general conversion is flywheel KW = rear wheel HP. a guy i know had a stock BA xr6t (one of the 240kw ones), it made 248rwhp (185kw). with the addition of a generic flashtune (minor tune to raise the boost, but the car was never put on the dyno, the tune was just a generic tune that the place he bought the flash tune off put on there before sending it out to him) and the boost raised to 9 and 11psi it made 300hp (224kw). not sure what boost setting that was on though.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
