Where did you get the brake adapters made?
Also on your splitter, do you have any pics please showing how you attached the ply to the garden edging? I'm guessing 90 degree alloy edging cut into small pieces
Pauly D is making them for me, can't wait to see the difference in braking!
They're little right angle brackets with a hole on each side. i got them from bunnings
and that bonnet and catches, so HAWWWWT
Thanks man. :thumbsup:
never really cared how it looked (in fact always prefered go>show) but now i want carbon all over it ! sooo light and good looking :)
car looking good mate, any more details on the brake dog bones?
is he able to make any for R33 GTST > 330mm rotors?
I'll have to ask, he was doing them as a favour for me. but im going a bit of a different way now - see below
this things a rig!!! love it!!
thanks man, means a lot coming from someone with a car like yours :)
i have just ordered a new Sparco Pro 2000 as i need to log book my car. i want to enter the CAMS NSW supersprints and apparently i fall into 4D category. i need add a couple of extra roll bars in too.
I also just ordered some new front brakes. Wilwood 4 pot superlites? they are a 330mm 2 piece rotor so should stop alright now. budget end of braking i know but should work really well i think.
  • 3 weeks later...
Brakes came last week. Got them trial fitted while waiting for some safty wire to show up.
old gear to show the difference
Sooo much more room over 32 cailpers. i had 1mm clearence before, now this...
and the bum hugger ready to go in
Thanks mang :)
Finally bit the bullet and bought an R33 gearbox, was $800 and local so couldn't say no.
I have two events this month, 1st is the SAU texi at Sutton and the 2nd is a TCC Interclub SS at wakie on the 27th. It will be the last drive until Nationals as my first born is due June 1st, im guessing I’ll be too tired for anything else :)
Got a bit to do over the next week so stay tuned for updates.
New seat will be put in this weekend and im going to make up some boot/wing supports to stop it flexing as well.
Saftywire finally came, bolts got all wired up.
not too bad for my first go at it.
all fitted up, will be bled tomorrow and bedded in.
(bought a pair of S13 BC coilovers for the front to replace the S14 ones it had)
yep, im a lucky sob.
took the dip at the SAU Texi day too quick and this is the result
LH LCA, castor rod and camber tops all came loose and moved. the only damage to the suspension was two of the camber plate bolt on the rh got bent when it moved in.
very lucky with this, actually bent it back
this was folded in half
watch the wheel move around after
http://www.youtube.com/watch?v=h_LFW0Uy03o
Starting making another quick splitter as i need it for this weekend
this one is being mounted to the chassis this time, made out of bits i had lying around. unfortunately since the lip got destroyed the air dam will be massive haha. About 6in tall, will look pox
    • I'm confirming the "2 way" Nismos can be converted to 1.5's very easily as you already described. It's well detailed in the manual. I can scan mine if you need, I think I still have it laying around somewhere.
    • Well, its worth noting that 450+ is probably enough to get you to church on time each Sunday already..... You mentioned cams, did you upgrade the valve springs as well? Factory ones will be well past their use case by now. And yes, the hydraulic lifters are likely to limit your usable rpms and AFAIK you need a (now rare and expensive) head swap to rb26 or even better rb25neo for that (to retain VCT) I don't think 4"/3.5" should be a restriction. What about the intake, do you have an upsized intercooler and what is the throttle body?
    • I also second realdash. I have it on my head unit as a secondary cluster talking canbus with my ecu. Works great.
    • Something like this -  You can buy the arms in different lengths too. The suction cup goes to the windscreen.
    • I do have an adjustable exhaust cam gear but I always presumed these only lead to minor changes. I'll play around with it next week and report back. Also wouldn't advancing, not retarding shift that power down lower?  We played around with VCT last year and it made more power with it on until redline. I had read somewhere that this is often the case with short runner intakes like I'm running but I'll revisit this after adjusting my exhaust cam.  I have a 4" downpipe and 3.5" line with two open dumps. I'm thinking back pressure would only start to be an issue at 35+ psi. I often hear people state things like "oh my turbo really only wakes up past 30psi" which goes against everything I know about centrifugal compressors. Is there any actual logic to this?  Thanks for the help dose.
