Cheap R33 GTsT 2 door S1 --- straight, undamaged --- 65k
Track/Parts use only
Lookin for at least $1500 complete
PICS are here: http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...IT#ht_582wt_932
Pickup Wollongong NSW - or can get you a cheap tow even to bris / melb
Info: call me on 0431339949
Has:
genuine nissan front bar (s2 or m spec?)
All its panels - straight
both doors
bonnet
boot
rear lights
Turbo LSD including cradle, drive shafts
tail shaft, both halves (auto)
Complete rear brakes
front discs and hubs
Complete power steer system
hicus system
Aircon/ heater
dash
TURBO CLUSTER WITH ONLY 65k
all the seats
door trims
rear trims
hoodlining
most glass
Wiring loom UNCUT
fuse box
billet steel flywheel, 3 puck clutch, RB30 5 speed box
16" wheels (300zx X3 and 1X R33) legal tread
combination switch
ignition with key
etc etc
Edited by dragon33
https://www.sau.com.au/forums/topic/343034-r33-gtst-parts-car/
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
