ok im getting rid of some parts that i have laying around from all my imports that i no longer have but need em gone so hear gos
s13:
sr20det bare head (was going to get this ported and polished the just swap over) $100 + postage
sr20det std clutch fan $30 +postage
sr20 std fan rad shroud $30 +postage or have both for $50
genuwine parker and indercator lenses (drivers side das had the push in clip snaped of but i still have so u can repair it) other than that good cond $40 +free postage
space saver spare wheel with good never used tyre $50
r32:
std air box buyer has not contacted me so back up for sale $70+ postage
r33:
std side mount intercooler with elbow $50 +postage
stockie rims and tyres x4 $150 for skids
good condition stockies with just road worthy tyres $250
power steering pump and resivor good cond $50 + postage
r34:
genuwine under car engine bash plate/gaurd in good cond ( save your under carage from damage) $40
text rossco on 0421506888 or pm me
all parts in bendigo
https://www.sau.com.au/forums/topic/343045-shed-clean-out-s13-r32-r33-r34/
prices are neg and the air box turns out to be an r33 are box it fits the s2 but i also have the lid for the s1 to go with it
  • 1 month later...
s13:
r32:
r33:
r34:
Hi do you still have the r32 air box?.
yes the air box is still hear
i have too bottom sections for it
one fits the r32 afm one fits the s2 rb25 afm
i also have a std gear nob from a silvia hear to
the one that sits nice and low over ther gear boot and is a heavy weight $40 + postage
  • 1 month later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
