  • Replies 181
front pipes $100
sunvisors $20 each
interior mirror $20
interior lights $40
dash loom $100
interior carpet $70
boot carpet $60
heaterbox/ all under dash make an offer: SOLD
rb26 cam/timing belt cover $70
speedo 140,xxxk's $50
brake calipers x 2, $100
intercooler mesh $30
trust pod filters x 2, $80
monster tacho with shift light $50: SOLD
steering wheel $50
GTR fuel pump exc. working order $90
glovebox $30: SOLD
HICAS computer $50 plus have other little computers from throughout the car
have ALL windows except drivers side
rear wiper + motor $40
boot release with fuel flap popper $40
side mirrors $50 each
bonnet squirters $20 pair
bonnet heatshield $60
A,B,C pillars
clutch master $40: SOLD
brake booster $60
accelorator with cable $50 brake and clutch pedals $30 each
steering rack $150: SOLD
metal plate that goes inbetween rear seat and boot $60: SOLD
windscreen wipers $30 pair: SOLD
window wiper motor $40
overflow and washer bottles
kickpanels $20 each
assorted cooler piping from gtr $50
wheelnuts $25
seatbelts
rearseat in mint condition $150
boot rubber seal perfect cond. $40
drivers door window switch $50
rb20 crossover piping $40
turbo timer exc. working order $30: SOLD
handbrake $30
random 8 inch subwoofer never been used $20
there's heaps more! the whole underside of the car is still there! diff, half shafts, hubs, the lot!
front pipes $100
sunvisors $20 each
interior mirror $20
interior lights $40
dash loom $100
interior carpet $70
boot carpet $60: SOLD
steering wheel $50
glovebox $30: SOLD
A,B,C pillars
brake booster $60
kickpanels $20 each
wheelnuts $25
seatbelts
handbrake $30
there's heaps more! parts galore, need the garage space! the whole underside of the car is still there! diff, half shafts, hubs, the lot!
Na mate gearbox was sold a long time ago
front pipes $100
sunvisors $20 each
interior mirror $20: SOLD
interior lights $40
dash loom $100
interior carpet $70
steering wheel $50
glovebox $30: SOLD
A,B,C pillars
brake booster $60
kickpanels $20 each
wheelnuts $25
seatbelts
handbrake $30
Drivers side reverse light: SOLD
O.N.O. on pretty much everything
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
