  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I wish you guys/gals lived closer, cause I'd come round and help
Ok then ;).. we had a play around a couple of hours ago .. riddle me this:
- coil packs swapped for complete other set
- spark plugs seem to be "about 0.8mm" (left feeler guage at home - oops) and were all fairly recently replaced.. NGK BCP6RES which i think come out these days stock at 0.8
- no obvious air leaks, split, or disconnect vacuum pipes
Which in my mind only could leave?
- Timing slightly out (couldn't check)
- not running cooler or aftermarket management which i know is a bit iffy at 10psi (although apparently it does it at stock boost levels too)
- ignition module (doubt it)
... OR ????
Running about 10psi boost, few random misses at around 4000rpm.. but can "push" thru till they start appearing at 5500rpm or so again. Not massive (heard worse) but enough to shit you when going hard.
So Dr Paul - what is your prognosis?
This is Ska's ka (oo that rhymes)... nah.. no SAFC .. no nothing - that is why I think its maybe a bit iffy even trying to wind the boost up on that setup. No real sign of audible pinging though. Actually almost seems to be the opposite... could it could be just running a bit rich, flooding the cylinders??
0.64mm ? interesting... he could try that.
I always used to run BCP6RES w/ 0.8mm on the rb25det and never had miss issues 10degrees or 35degrees.. but i did have a big front mount and SAFC.
well at least i found out my "spare" coilpacks work.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
