  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
but i have things that need doing.. i need the concise MCSIII .. maybe i'll just go for a drive, then go home b4 lunch.
speaking of funny stories.. this one was funny.. it lasted 5 minutes before getting "killed" itself.. haha
http://www.skylinesaustralia.com/forums/sh...ead.php?t=56891
Well at least we can sell stuff, maybe sometimes for the wrong price, but meh at least we can sell stuff.
Hey strutto, come on saturday, they are going to have the home hardware dogs, and showbags for kids and giveaway's and free food and stuff, just up the road, or anyone for that matter, Come one Come all and be OVERCHARGED BECAUSE OF Ska's Inability to code in X++ :)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
