  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
rofl over here optimax is as good as woolworth unleaded after a few wks :)
really? the again a full tank of fuel on a weekend only lasted a night when i was in qld. drive from ipswich to the coast cruise around and back again. it didnt last long
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
