  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
your in japan for TAS and your complaining?  :usuck:
hahaha
with the short bus trip from airport to subway, already seen a fair of bit mild VIP cars/skylines/turbo kei cars etc :D
btw first taxi I got in was a cedric running on lpg.. quite nice inside too :)
hahaha
with the short bus trip from airport to subway, already seen a fair of bit mild VIP cars/skylines/turbo kei cars etc :)
picsorban! :(
Can someone get a price for a tomei cam gear for me off the nengun website? I can't remember my log in and password :(
$237 delivered Tomie
$208 delivered Apexi
$198 delivered HKS new madel light weight like the Tomie
You are a bit too late
I sold a brand new prior to xmas for $160 delivered
Was flat getting someone to buy it
I have some used rb25det Tomie poncams being set over at the monemt from Japan. Can't wait :)
Thanks Darrin and Josh.
I've forgotten (don't know) my login but it's saved at home.. but not at work so I couldn't get in to see the prices.
Apparently theres a place called AVO down in Sydney who provides adjustable cam gears for RB30's so I'm not sure what he's going to buy now.
Hrm.. apparently a Gislers chick is going to be coming around here at smoko from now on. I told them to make sure she was a blonde with big tits and short pants :)
I dont think they took me seriously.
not hard to find those typical gisler chics :(
