  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
dork!
OH OH and you want some of this beatdown you wetern australian dirty inbred?!?!
I have had a shi7 of a day and Charly is just being a passive little biatch like he normally is, musta taken his drugs today! :flamed:
get AIDS and DIE MOFO!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
