Women do the laundry every couple of days. A man will wear every article of clothing he owns, including his surgical pants that were really hip about eight years ago, before he will do the laundry. When he is finally out of clothes, he will wear a dirty sweatsuit inside out, rent a U-Haul and take his mountain of dirty clothes to the Laundromat. Men always expect to met beautiful women at the Laundromat, but this is only a myth perpetuated by old reruns of Love American Style.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I have 10 musical devices in my puter room...
1 puter
2 metronome
3 guitar tuner
4 electric organ
5 electic piano
6 electic guitar
7 electric bass guitar
8 flute...........this one time, at band camp..........lmao
9 Yamaha FB-01 sound generator
10 Roland PR-100 digital sequencer
User Name Posts
chaos 6485
Ska 5423
BelGarion 3724
predator 3216
Nexus9 3080
strutto 3062
Genesis® 2674
Lazy-Bastard 2392
SmoothLine 2221
Charly 1838
NismoGirl 1827
Eug 1550
TeamKrazy 1493
jaqule 1423
NA_R33 1374
Nismo_Boy 1298
owned 1175
Oz 990
PlATiuM 989
FYN33 980
GTS-t VSPEC 806
rb25 735
EVO83 700
mindflux 650
wados 645
Nizmo 588
sileighty 558
Squizz 529
MJ 520
jlnewton 511
33NIZ 477
666DAN 440
rb26dett 351
V8skylineMAN 339
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
